Manual box gearbox oil change
Hi
Skoda superb 2018 2 litre 190 diesel with 6 speed manual.
I am trying to change the gearbox oil and cannot find the fill plug only the drain plug.
My question is does it have one?
I found a YT vid for 2016 passat same engine that has a fill plug but on my box casting there is just a flat with no hole in the place where the passat has one...
Haynes skoda superb manual is useless just has a generic instruction but it does mention some vehicles are filled from a breather valve hole on top of the box
Does anyone have any experience - tips?
oh and please dont say its filled for life - I am an engineer and dont believe in fill for life advice, plus i am planning to keep the car for many years
Thanks in advance..
simon
Welcome.
You need to find out your gearbox code as that'll then give some pointers :)
Looking at the workshop manuals I've got:
- some have filler holes
- some go via the reverse light switch
- some have a special filler hole which require an adaptor
Hi @simonpa,
Maybe you can find the answer on cardiagn.com, where you can download workshop manuals for free. ;)
Just searching for something similar a few days ago:
In the karoq section of this forum theres a gearbox manual that also covers some other models- same gearboxes used- including various diesel engined Superbs 2015-
The details are in there for filling with a special tool , or via a funnel/ tube through an alternative route- after removing specific bolt/ fittings along with the volumes required.
(p.s. a manual covering some recent Superb engines, including likes of recent DSRA /B motors are in the Kodiac section.)
Edited by Shuggyboatsuperb
15 hours ago, simonpa said:
Hi
Thanks in advance..
simon
Can't help with fill and drain on your engine, they are pretty easy to spot on my 6 speed manual (1.4tsi), but you're absolutely right it is well worth changing. I did mine a couple of years ago and it came out in pretty poor shape. Can't say I noticed much difference in quietness or shifting but it was good to know that it was back up to spec.
  • 1 year later...
Hello there!
I ran into the same problem, have you found where the fillhole plug is?
  • 8 months later...
Thanks all for replying especially the guy who put the link to the workshop manual.
It’s finally done, I filled the oil after removing this plug- see pic. Fitted a new plug also new copper washer on drain plug for peace of mind and happy days!😀👍
