Airbag Release Ring Clock Spring
Hi, here are 3 photos of my Airbag Release spring, and a 4th of a stock photo, I took mine off as I am replacing a faulty combination stalk (headlight stalk). Looking at the Yellow label, to me it is saying that I have to line up the inner cable. How accurate should this be? Will it be alright in the position as shown? I did look at it when I took it off and never saw the cable, so turned it around to see what/where the cable was.
Also, again on the Yellow label it is showing to small black triangles that need to be lined up. I can see one such triangle in the shinny area of the first photo, opposite to the white label.
What does this line up with?
Mine does not have the white plastic thing that is shown in the last photo attached to one of the prongs, does this matter?
Sorry for all the questions, I suffer from severe anxiety, resulting in anything & everything causing me a lot of stress, plus lack of confidence.
Thank you, not the first time I have gone wrong at the beginning of something 🙂
I have asked admin to remove it and I have just put it in the Roomster section, though I do wonder if it will be ok to also put it in the Fabia section as it can be found in some of those along with VW Polos.
  • Thanks 1
