Turning indicators going crazy
On my Superb II the turning indicator started to behave rather strangely this morning. When indicating either left or right, always the left side indicator lights were turned on. Yes, I turned the stalk to indicate right and the left side indicators started blinking. Never thought this would be possible. After having the engine running for a few minutes, it worked fine again. Any ideas what it could be?
First thing I always think of , to keep things simple and basic and hands clean, check the battery terminal clamp connections are clean and secure and same for main live and  earth cables and connections, that the battery is at a good state of charge.  Then I might consider the stalk internal connections (and grease) might have a fault(s).
If you have access to a good level (above generic code reader) VW appropriate scan tool get a report and if possible tests.  You could see if there's a member near to you that might be able to help with this from following link. -Briskoda VCDS Owners Map (click me)
HTH.
