Engine Control Module Issues
Hi,
I have issues with my ECM. Is it a simple case of buying a used one online and swapping them out or are there other factors and routes I must take?
I've attached an image of it.
Thanks all :)
What makes you believe that?
What the garage has said perhaps?
Hi, yes, diagnosed by my mechanic. Erratic issues with starting. Cheers
If he hasn't tried a replacement then I'm inclined to think he's just guessing.
It’s been tested.
Things will need recoding, immobiliser, radio, and probably much more.
= I am beyond my skillset now, I really dont know what the problem is, I want to see the back of the car and the customer.
36 minutes ago, Inza said:
It’s been tested.
By said mechanic no doubt?
He took it out and checked everything and before he took it out he plugged his iPad looking thing into the car. He’s a certified VAG mechanic.
Good luck then! 🤣
Edited by J.R.
