Minor forum shuffle
We've just done a minor forum shuffle, more to come, but if you;ve had a PM saying your thread has moved, please ignore if it was issued in the last hour.
For information, suggestion zone is now part of help and feedback, removed as they duplicated each other.
Freedom forums realigned.
Forum home is split to offer greater visibility to news / announcements, others will follow format as needed.
Lot's more cleaning done. If you're missing stuff which you can't do without, let me know and I'll see if I can revive it.
Am also updating permissions on some of the forums to be more transparent. If you suddenly stopped getting access to something, please don't take it personal, it is just me resetting/setting things.
If it persists over a day, please contact me and I'll see what has caused it.
The "Maintenence and Performance" section doesnt really contain any Performance related sub-forums any more. May be worth re-naming ;)
  • Administrators
A point to be taken in to consideration for sure, unless some performance type items appear in there...
All: Please note that as a part of this we will be running some maintenance scripts. These WILL adjust your post numbers and that of posts within forums. If you loose a few posts from your post count; chill out, the database won;t give it a second thought; nor should thee.
A point to be taken in to consideration for sure' date=' unless some performance type items appear in there...
All: Please note that as a part of this we will be running some maintenance scripts. These WILL adjust your post numbers and that of posts within forums. If you loose a few posts from your post count; chill out, the database won;t give it a second thought; nor should thee.[/quote']
Thanks for the warning Colin. Thought I'd better up my post count today, just in case :D
Have a restful day - sounds like you'll be glad of that come tomorrow night, so hope all goes to plan.
Mo
