Software trouble after new keys on 2014 1.4 TSI RAPID
Recommended Posts
Skoda rapid 2014 1.4TSI DSG. 260.000km
Ok, so I got a spare key coded in, and it works. But... Now the steering wheel angle module (or something like that) went completely haywire.
Done by a professional shop, which explained that this happens with one in a thousand, and that it needs to see a shop with login codes etc.
They will cover the cost, but I'm seeking help to see if I can fix it myself earlier, as I can't really be without the car for long, and i expect it to be at a shop far away for long. Car drives, but lamps are blinking and abs/tcs/esp etc is not working at all.
I went to a vag-garage close to my home, but they were a little short on time and couldn't take a deeper look. They told me they tried deleting fault codes, and reset the coding on the affected module as well as doing a factory reset, but didn't succeed in removing the issue.
I don't know the name of the system the key-tech used, but it was a large apparatus with obd contact, screen and a key reader/slot.
Is there anything I can do myself with VCDS? I've read fault codes, and module 04 - steering wheel angle does not at all communicate with the diagnosis tool.
Monday,25,March,2024,18:28:54:35578
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: TMBET6NH1E4523977   License Plate:
Mileage: 252380km-156821mi   Repair Order:
Chassis Type: NH-SK25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 37 44 56 61 69 0B
VIN: TMBET6NH1E4523977   Mileage: 252380km-156821miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 GD    HW: 03C 906 016 GD
   Component: 1.4l R4 TSI   H01 4583
   Revision: LPH01---    Serial number:                CVN: F291B5BC
   Coding: 00250032002401000000
   Shop #: WSC 73430 031 00016
   ASAM Dataset: EV_ECM14TFS01103C906016GD 001003
   ROD: EV_ECM14TFS01103C906016GD.rod
   VCID: 678BB7CBDFE57B928E9-8032
   VINID: 91D4959067980551050832471CDA5CE923
No fault code found.
Readiness: 1110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 062 M    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501401155558
   Coding: 0000020
   Shop #: WSC 51729 001 1048576
   VCID: 36352A8FC44FD21AC5F-8062
Address 03: ABS Brakes (J104)       Labels:. 6R0-614-517-TRW460.clb
   Part No SW: 6R0 614 517 BK    HW: 6R0 614 517 BK
   Component: EBC 460 ESP   H08 0004
   Serial number: A00ICBD
   Coding: 4129481489B300B7825012D991A700504B0800
   Shop #: WSC 73430 031 00021
   ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
   ROD: EV_Brake1ESPAEntryTRW.rod
   VCID: 7DA7F5A3AD79C142445-8028
2 Faults Found:
0360 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
          MIL ON - Confirmed - Tested Since Memory Clear
0405 - Incorrect Vehicle Type
          U10D9 00 [10001001] - -
          [CHASSINF_CAR_TYPE_MISMATCH]
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 252381 km
                    Date: 2024.03.25
                    Time: 18:06:47
                    DTC: 00 01 95
Address 08: Auto HVAC (J255)       Labels: 6Q0-907-044.lbl
   Part No SW: 5JA 907 044     HW: 5JA 907 044
   Component: Climatronic   H04 0106
   Revision: A1001000    Serial number:  1311191A-0046
   VCID: 78A9E4B782DBE46A173-802C
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 018140590
   Coding: 62980B0000010000000801306E0B0DD00EC0400F608E0040020000004000
   Shop #: WSC 73430 790 00021
   VCID: 2D0705E33D1991C2B45-8078
   Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B0626240114
   Coding: 820000
Address 10: Park/Steer Assist (J446)       Labels:| 5JA-919-475.clb
   Part No SW: 5JA 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 3K  H11 0005
   Revision: --------    Serial number: 32901401600160
   Coding: 110103
   ASAM Dataset: EV_EPHVA14SK25X0000 001002
   ROD: EV_EPHVA14SK25X0000.rod
   VCID: 44D140478E13708A4BB-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 34D 959 655 B    HW: 34D 959 655 B
   Component: AirbagVW20    004 0365
   Serial number: 003K7R02TEU3 Dataset Number: 5JA003t____ 0013
   Coding: 88CCC00000000000540000C8000000000065
   ASAM Dataset: EV_AirbaVW20SMEVW253 001108
   ROD: EV_AirbaVW20SMEVW253.rod
   VCID: 34311087DEB3C00AFBB-8060
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Df  003 0148
   Serial number: 349651A016EB02A48D9U
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Pf  003 0148
   Serial number: 350651A0119A0D543C35
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Dr  003 0148
   Serial number: 351651A0146C4F02CFAQ
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Pr  003 0148
   Serial number: 352651A0119C89234FAK
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5JA 920 840 D    HW: 5JA 920 840 D
   Component: KOMBI         H04 0709
   Serial number: 00000000000000
   Coding: 111E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
   VCID: 3B233BBBF3ED0F723A1-806E
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 932200
   VCID: 70B9DC97EAABBC2ADF3-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0709
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8DCEFFCCF746FA917-803E
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7665752742
   Coding: 030100
   VCID: 2B030BFB030D9FF2AA1-807E
Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
   Part No SW: 5JA 035 192 J    HW: 5JA 035 192 J
   Component: RNS315-EU   H76 0410
   Serial number: SKZAZ2P0041600
   Coding: 040004010207000001000002
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 3E2532AFE0FF1A5A1DF-806A
   Data carrier:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_V5  0055
2 Faults Found:
1048632 - Antenna 1 for Radio
          B1119 13 [00001001] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 252381 km
                    Date: 2024.03.25
                    Time: 17:52:57
1048636 - Digital Radio Antenna
          B1103 13 [00001001] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 252381 km
                    Date: 2024.03.25
                    Time: 17:52:57
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  311 3111
   Serial number: CE1V0003 Dataset Number: 5JJ074t____ 0009
   Coding: 0003
   Shop #: WSC 57209 005 104857
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 46D55A4FB82F429A55F-8012
4 Faults Found:
1094656 - Steering angle sensor
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 252381 km
                    Date: 2024.03.25
                    Time: 18:18:06
1091584 - invalid data record
          B2005 00 [00001001] - -
          [DEM_INVALID_DATASET_FAULT]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 252381 km
                    Date: 2024.03.25
                    Time: 18:18:06
1073664 - Steering End Stops Not Learned
          C10AC F0 [10001001] - Unknown Error Elaboration
          [DEM_LEFT_ENDSTOP_NOT_KNOWN]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 252381 km
                    Date: 2024.03.25
                    Time: 18:18:06
1073920 - Steering End Stops Not Learned
          [DEM_RIGHT_ENDSTOP_NOT_KNOWN]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 252381 km
                    Date: 2024.03.25
                    Time: 18:18:06
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 032B7A64
   VCID: 6B83CBFBC38D5FF2EA1-803E
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 51007K09162031593138
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00008200034725
   Coding: 410D000100000000
   VCID: 30391C972A2BFC2A9F3-8064
End----(Elapsed Time: 01:32, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
25.3.2024 kl 1830.txt
Link to comment
Share on other sites
Posted (edited)
4 hours ago, Rooted said:
Welcome.
What kind of professional shop?   Is that 1 in 1,000 of their work?  that sounds pure BS.
Specialized locksmith. I drive a tow truck, several of my collegues with 15+ years of experience also testified to this shop being the best place to go with any car key related problems. When I told them what happened, they had never heard of or experienced anything similar (And my work also use them often). Also a plus that they're about 10-20% cheaper than any dealer workshop. I've never seen or heard negative reviews of them (And I've looked thoughly), they've been in the business for the good part of 20 years, I practically cannot find anyone with same issues online. I have no reason to doubt them, and they are helping to get it fixed, I'm just impatient and want my car available. This is in Norway btw.
But that wasn't really what I'm here for feedback on, do you have any suggestions?
Edited by Steinrawr
Link to comment
This link any help ?
https://forums.ross-tech.com/index.php?threads/39449/
Link to comment
Thanks, gives me hope it can be solved. But certainly not by me, as it seems like the steering angle module must be taken out and reloaded with software. Mine also seems to be completely empty, like the one linked on Ross-tech.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
