Head lights
VRS 2010 fabia hatchback.
 Head lights are two small lights low down at the front.However there are two lights not being used how can these be used.
(Not the main beam they work fine)
Is it a simple mode to get these working.
Thanks everyone.
Those are the original side lights/marker/parking lights. The vRS has that feature moved to the DRL/fog lights so the bulbs in the actual head light unit are redundant. There are threads here about getting them activated again though so try a search and see how you get on.
The dummy blue bulbs that are in where the sidelight bulbs would have been will not help light things up better than the dipped beam or full beam that is in the headlight.    @UrbanPanzer has a thread with them back as sidelights.      There are no Front Fog lights.  The low units are the DRL,s when no headlight on and when on they are dimmer and are the Sidelights / position lights.    In the Fabia section are threads on failing  MOT,s because testers think the Dummy Blue bulb place should have sidelights working there.
Edited by Rooted
