VCP / ODIS help required Suffolk UK
Hi, long time reader of the forum but just signed up. I'm retrofitting a number of genuine parts to a T6.1Transporter and need some help with the following issues. I've installed a new TPMS module, all coded etc and only one fault. Apologies in advance for my first post asking for help
I've a new TPMS module that needs parameter file uploaded
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 D HW: 5Q0 907 273
Component: RDKBERU30 H06 0010
Serial number: 30000000707352
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_VW41.rod
VCID: 363528CC18C9A54AC5F-8062
1 Fault Found:
12652550 - invalid data record
and I have a HBA Mirror that was originally from a SEAT Alhambra that is coded for PQ not MQB that needs to be recoded
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 AK HW: 3G0 857 511 AE
Component: FLA H10 0003
Revision: AA001001
Coding: 040401E201000000000000
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 71BFDBD03127C272D0D-8024
Hoping someone can help £££££££ / Beer
Many thanks in advance
  • Administrators
Have moved this to our vcds/diagnostics. Bit more travelled than the non skoda projects bit.
hopefully a knowledgeable member will be along shortly ;)
I'm not super far away and I've got ODIS somewhere, I need to dig out the right laptop and make sure it still works.
I've done a parameter upload on my TPMS module previously:
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
So I assume the D rev should be a near identical process.
As for the HBA mirror, you need to reflash it rather than recode it based on the instructions here: https://www.drive2.ru/l/606426293524771900/
It's somewhat more risky but might work :)
Thank you
OK, thanks, can you let me know how to contact you for the TPMS.
With the HBA, I'm thinking that I may have to bite the bullet and buy a MQB one and sell the PQ one I have
Many thanks, Nick
Drop me a PM :)
Either here or on Ross-tech forums, same username.
