How to remove Karoq rear light unit
Yoda1247
Recommended Posts
I've been advised by my dealer that I should replace the rear light unit as there is quite a lot of condensation. Suggested cost was over £400! Thought I might try it myself but wasn't sure how. It's a Skoda Karoq 2.0 TDI Edition 4, 2018.
Any help greatly appreciated.
Link to comment
Share on other sites
Is it the inner light on the tailgate or the outer one on the rear wing?
Link to comment
Ok.  I'm pretty sure it will be the same as the Kodiaq or similar...   So there should be a removable flap or plastic vent inside the boot (behind the lens) which reveals a plastic screw.  Undo this and the lens should come away from the car quite easily, albeit it has a rubber seal against the bodywork so might be a bit stuck. You should then be able to unplug the connector and possibly an indicator bulb holder to remove the lens so you can get it inside to dry out.
You'll probably find more instructions in the bulb changing section of the handbook.
Edited by skomaz
Link to comment
Thanks Skomaz. Followed your suggestions - removed the unit which is now almost dried out - it appears to have been the seal in the lampholder, which was the problem. One it's fully dried (hairdryer very useful here!) I'll re-install it and keep an eye on it.
Thanks again. Much appreciated!
  • Love it! 1
Link to comment
Excellent...   Better than giving the dealer £400 for something that wasn't needed!
  • Like 1
Link to comment
Quote
Really ? I remember when I had an Audi, the bulb changing section in the handbook had one short paragraph of instructions , 'Take to your Audi dealer' 😀
  • Haha 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
