Radio turns off with ignition off
Hi all.
I have an octavia mk2 facelift.
The radio used to turn off when I removed the key from the ignition switch (and the doors unlocked). I tweaked around in VCDS and now it is turning off with the engine.
I looked up the ignition switch terminals and found the s-contact/ s-terminal.
The switch itself is working correctly (contact opens when I remove the key), but te CANbus data says it's off when the ignition(engine) is turned off.
And I can't find any settings or solutions about it.
Thanks for replys
Pretty certain there's a setting in the radio itself to change that.
The problem is that the radio is getting the wrong information from the CANbus, but the physical input is working fine.
I checked all the settings and couldn't find anything
