Passenger Side Front Door Won't Open
Please can anyone help? I have a mk1 Octavia Elegance 1.9 tdi, and the MOT runs out on 7th July. The main problem I have to sort out before the MOT expires is that the passenger front door will not unlock nor open.
  • Administrators
Sorry for late reply, did you manage to sort this out?
Try pulling the handle on the inside while repeatedly pressing the unlock button on the driver's door.
I did manage to get it open. The repeated hitting the door and pulling the handle didn't work, then I removed the door card and tried connecting a 12v battery directly to the wires that go to the actuator. At first I thought this would work, as it did make a whirring noise, but still didn't unlock and then the noise stopped, suggesting the motor was totally burned out.
The way I got it open was to use a Dremel type tool to cut a hole in the side of the door lock (near the top) IMG-20240630-WA0002.thumb.jpeg.7f12f3360c2df6fe3e9cc6ad31dd1134.jpegand then pushed the "plunger" up manually, using a screwdriver; turning the cog (visible through the bottom hole) didn't work, as it just kept spinning back against the resistance.IMG_20240630_201906.thumb.jpg.3adc7f977c2230c426df9c9d50c0851e.jpg
