2001 Octy vRS Oil Pressure Switch
Where is this located? Another thread mentioned just above the oil filter - but I can't find it!!
It all looks a bit tight in that location - if it is there do you have any tips to help replacing it - ie which bits should I remove from around it to make the job easier.
Finally , if it has gone - should it show as an error code in VAG-Com?
Wont show a fault code.
It is just above the oil filter, single terminal plug.
you might be after this then Clicky
Cheers mattbeef - it all makes sence when you see a diagram - I was fishing around on the block!!
no worries mate think i found it on ukmkv forum and found it rather useful
Glad it helpped you out mate
a1 is that avatar a car that you crashed? Looks a bit liek an Octy VRs from the small pic I can see.
Hi cheeze..............
This is the car that I bought crashed and had repaired. There were some threads on it over 2 years ago , for those members that have a good memory.
I did have pictures in my gallery , but they seem to have disappeared.
I still have the car and it is still going strong. This oil pressure switch is the first problem I have had since it went back on the road over 2 years ago. (Excluding the air con , which has never been right!!)
Cheers , Steve.
Back on topic -
Is there a test I can do to make sure the switch /sensor is def faulty?
At the moment I get the red oil can dash warning light come on even though the oil level is fine.
Don't want to scare you but the sender could be fine...! the oil pump could be shot.. Just because there's oil in there doesn't mean it's getting pumped anywhere. Just another possibility.:eek:
A useful reference and well worth keeping a copy of if you are into DIY.
You're right , but using the process of elimination (and keeping my fingers and toes crossed) I though I'd start with a
