Blind Spot Sensor
Just recently added 2 Superb Estates to my fleet. One of them, 2019 2.0Tdi Technology the Blind Spot Sensor is not 'permanently' set to on so need to go into the Car Settings every time the car is started to tick the box and switch it on. Anybody know the sequence to switch it on through VCDS meaning you would need to go into the car settings to switch it off?
It will do this when there are fault codes stored in certain modules of the car that may effect the blind spot assist.
Youll need to clear all modules of faults first then post a full fault scan afterwards of what comes back.
The blind spot will stay on even after ignition cycles unless there are faults stored.
