Cooling fan problem.
Fans wont turn on, car overheats idle.
changed one defect fan, both now work with direct battery supply, changed the relay under the battery.
still wont come on.
i cant find any wiring diagram for this. anyone has them?
other tips?
  • Sponsor
VIN/chassis number required to get sufficient data about the vehicle to find best wiring information, please.
Edited by Breezy_Pete
sorry.
TMBJX11U638690186
BFQ
The system for the BFQ is unique across the 1U platform.
Radiator fan control unit, radiator fan, air conditioning system magnetic coupling
J110- Central locking control unit
J293 - Radiator fan control unit
J393 - Convenience electric central control unit
N25 - Air conditioning system magnetic coupling
T2r - 2-pin connector, for air conditioning system magnetic coupling
T3h - 3-pin connector, in the holder on the left radiator
T3s - 3-pin connector, in the holder on the left radiator
T4r - 4-pin connector, at radiator fan control unit
T4t - 4-pin connector, in the holder on the starter
T14a - 14-pin connector, at radiator fan control unit
T14b - 14-pin connector, on front left in engine compartment (black)
T15a - 15-pin connector, at central locking control unit / at convenience electric central control unit
V7 - Radiator fan
V35 - Radiator fan, right
12a - Earth point -2-, below the battery on the left
188 - Earth connection, in front left wiring harness
A49 - Connection -1-, in wiring harness behind dash panel
L5 - Connection -1-, in front left wiring harness
L6 - Connection -2-, in front left wiring harness
* - only for vehicles with anti-theft alarm system
  • Sponsor
I'm going to PM you with some info in a minute.
Edit: unless @Crasher has already done enough!
all the fuses is okay.
the 4-pin connector, at radiator fan control unit seems to be working as intended.
the termostat is changed, and all the temp sensors change resistance with temperature.
so the 14-pin connector, at radiator fan control unit:
T14/4 and T14/9 both gives 14.1v
/2 from G65 High pressure sender (which im not sure what is, or located) gives 0.72volts.
/8 gives 0 volts but 14.1v with AC on. not sure where this is going either.
/3 - 0.02 volts not sure what this is either.
/10 - 0.00v
/6 - 0.00v
/13 which goes to Central locking control unit, dash panel and Convenience electric central control unit
fluctuates pretty fast, 5v-10v-12v-5v-10v-12v-5v-10v-12v and so on.
which is weird?? or normal? xD
/11 and /7 which goes to the ECU i believe shows 0v with car off, and 0.02 - 0.03v with car on.
so pretty dead? nothing happends here as temp increase either.
suggestions? : )
i ran 12v from the battery into the white wire in the g65 connector and the fans turned on.
is this a problem with the
refrigerant? can i remove the sensor without any other problems occuring with the ac system?
the white wire is also connected to the ECU, why?
