Brake disc size
Hi all
Im getting conflicting information here on brake disc sizes, I don’t know what’s correct. I have a 2014 VRs diesel
looking for front and rear sizes and which disc and pad is best to use ? Oem, trw etc
The Octavia MK3 2.0TDI VRS pre-facelift might have 340x30mm front discs and 272x10mm rear discs. To be sure, it's always best to check the car's build codes. However, if your rear brake discs are solid (ie. not ventilated) they will be 272x10mm. If you've got the big 340x30mm front brake discs you won't be able to fit 16" rims over them (or more specifically, over the front brake calipers), ie. 17" rims are the minimum size for these big front discs.
Jurid are a lower cost option than TRW and ATE, but should still be OE quality.
Octavia MK3 Brake Pads and Brake Discs
TRW Front Brake Pads
1ZF 276x24mm TRW GDB2080
1ZE 288x25mm TRW GDB1956
1ZA 312x25mm TRW GDB1956
1ZB 312x25mm TRW GDB1956
1LG 340x30mm TRW GDB2114
TRW Rear Brake Pads
1KD 253x10mm TRW GDB1330
1KS 272x10mm TRW GDB2042
1KT 272x10mm TRW GDB2042
1KW 310x22mm TRW GDB1622
ATE Front Brake Discs
1ZF 276x24mm ATE 24012402581
1ZE 288x25mm ATE 24012501451
1ZA 312x25mm ATE 24012501581
1ZB 312x25mm ATE 24012501581
1LG 340x30mm ATE 24013002251
ATE Rear Brake Discs
1KD 253x10mm ATE 24011002771 (pre-facelift model)
1KD 253x10mm ATE 24011004201 (facelift model)
1KS 272x10mm ATE 24011003561
1KT 272x10mm ATE 24011003561
1KW 310x22mm ATE 24012202191
Jurid 340x30mm front brake disc 1LG
https://www.autodoc.co.uk/jurid/13793869#brake-disc
Jurid 272x10mm rear brake disc 1KT
https://www.autodoc.co.uk/jurid/7863996#brake-disc
Edited by Carlston
You have to check front disc size on the actual car, earlier diesel vRS came with 340mm brakes, certainly in 2016 they were only 312mm brakes. Not sure at which point the size has changed. I like ATE ceramic pads, then EBC yellowstuff (road, not track).
Hi guys, thanks for the replies! Yeh mine is 2014 registered in January .. haven’t had a chance double check on the disc a size or build number, thought their was just one fitment for the diesel Pre FL not 2 or 3 different sizes 😅
