P3007 and P1650 error codes (camshaft position sensor, Skoda Octavia Scout 2008 2.0 BMM Engine)
Hello,
I get the following error messages when i connect the iCarsoft CR Max device:
P3007 - Camshaft position Sensor - no signal
and
P1650
-Databus drivetrain - Powertrain Data Bus: Missing Message from Instrument Cluster.
The car often stutters on 2nd gear, cranks for an extended period of time no matter if cold or warm climate, sometimes doesn't start in the winter etc.
The issue is definitely connected to the camshaft position sensor. I tried changing the sensor without it making any difference, the camshaft position sensor error code is still there. Hence, it should be the ECU or the cables for the connector.
I did measure the 2 (electricity) + 1 (earth) cables on the connector. I am wondering how much electricity they should have - what is the correct value for my specific vehicle?
Also, in this video, 7 minutes 50 seconds in, he changes the torsion value by loosing the 3 bolts and moving them to the ''middle''... I tried doing this but no difference... Should the bolts really be in the middle for my specific vehicle as well? They were outmost on the side when i first looked.
