Headlight condensation/air vents location
Hi all, my Fabia Monte Carlo drivers headlight is regularly suffering with condensation and has got significantly worse over the past few months. I realise that the weather and temperature make all the difference and in the sunlight it does dry out eventually. However, the condensation quickly returns most days. I've used Google and YouTube and seen various articles and videos and suspect it may be a blocked air vent that is causing the issue as I can't see any leaks or chips to the actual headlight unit and there isn't any water build up inside. Whilst all the articles are useful in identifying the issue, I haven't found one that actually pinpoints where the air vents are located on the drivers side headlight. There isn't a great deal of room between the back of the unit and the rest of the engine bay and so has anyone got any photos or diagrams that will help me please? Many thanks.
  • 4 weeks later...
Did you have any luck solving this.  My parents are having the same problem on their fabia
No joy, I'm afraid. I did however speak to my mechanic and he has suggested that this won't be an MOT failure as long as I put the headlight on high beam and dry out the casing immediately before I take it for it's yearly test. The MOT was my only fear as I've got the Monte Carlo model and the headlight is the black rather than chrome version. Sourcing a replacement is a nightmare and they only seem to be available from Lithuania and cost around £400 and that's before paying to have it fitted. 🙈
  • 1 year later...
Still having issues with condensation in the headlight and so whilst I have identified where the large rubber breather covers are on the headlight, there are also supposed to be one or two elbow shaped rubber breather pipes/valves on the rear of the headlight that may need cleaning out. Does anyone know where these are and can perhaps show them on a photo or diagram please ? I've asked Claude AI and ChatGPT but neither of them can provide photographic help. Thanks all.
I had similar with the passenger side headlight on my daughter's Citigo and after a close look the only thing I could spot was that run off from the bonnet dripped between it and the wing directly onto the indicator bulb holder. So I took that out and used some silicon grease on its rubber seal, put some strategically placed duct tape over the top of it to the inner wing to redirect drips away from it and also ran a length of PTFE electrical tape over the top of the headlight where the glass meets the plastic body of the light unit. It's been dry with no condensation since.
I'm not sure if the Fabia might be similar but it's probably worth a look / try?
Edited by skomaz
Skomaz - thanks for replying and for the suggestion. I've put some clear tape all the way along the join of the glass and plastic body of the headlight and so will see what happens. The dust cap seals both seem fine and from what I can see, there aren't any cracks or hairline fractures anywhere in the headlight. So puzzling and annoying as on a dry sunny day the condensation disappears within a couple of hours and it's evident there isn't any collection of water and so it seems to be a breather type issue rather than a cracked or damaged headlight. Typically the MOT is due in January and so the condensation is usually worse than ever. Last year they failed it but then cleared it with compressed air but I'm desparate to get to the bottom of the issue as I'm not so sure they'll be so understanding this year. Thanks again.
Skomaz - success (I hope) !! I had a closer look at the join between the headlight glass and the black casing and there appeared to have been a minute gap, literally millimeters but crucial. I've run a clear piece of tape all the way along the join and despite rain and a dip in overnight temperatures, the headlight lens has remained perfectly clear for nearly a week now. 😀I'm hoping this has finally solved the issue and so thanks for your feedback. I just need to make sure the tape stays adhered now but if the worst comes to the worst, I now know what the issue is and I can easily put some clear silicone along the join. Cheers Skomaz. 👏
Glad it seems to be sorted and fingers crossed it stays that way.
