Fuse Box Engine Compartment
Hi
I want to install a LED light strip in the front.
I can not figure out what fuse to use.
I need a fuse that turns on when i turn on the car.
Does anyone know what fuse would be a good idea to use?
If it was me, I would probably use an inline fuse on a wire from the battery, to the leds, then a relay to the DRl's, side lights or headlights to switch it on and off. My other option would be to do the same from the battery but have a switch wired into the cabin.
While a lot of people probably don't have any problem, I personaly wouldn't be comfortable messing with the under bonnet fuses, as they deal with the more sensitive systems, than the ones we normaly would use from the cabin fusebox.
