Help....
Could anyone help me with this? I do have it booked in with a garage,but I'm just curious if anyone else has had similar issues.
The lights don't always stay on. Some times they'll go off for weeks at a time and then they're back again. I though the issue had kinda resolved itself but here we are again. Has anyone else experienced this?
It's a 2017 Kodiaq (auto)
Had a similar array of intermittent faults on my Superb 2 when had a failing ABS wheel sensor.  So many systems are tied into wheel speed measurement a single sensor can cause many seeming unrelated systems to go into fault.  A quick scan by vcds or similar will confirm root cause.
Ditto happened on my superb 2 was intermittent also until speed/abs sensor and hub/bearing replaced.
