Clear airbag light?
Hi,
Had the steering wheel and airbag off to change ignition barrel and I know I powered car up with airbag disconnected so I'm not surprised the air bag light is on and MFS says "airbag fault".
My OBD scanner says no faults found as does a friend's one.... How can I reset the light please? Do I need VCDS or similar?
Car is Fabia 1.2 tsi 2013
For info, the 1st scanner was like the attached and the 2nd a Bluetooth one with Torque app
I think you require VCDS for this. OBD II scanners normally only give engine-related info.
Edited by Jocko
Thanks 👍
