Help on Acceleration problems
Hi
I bought a Skoda Fabia 2008 2 years ago and absolutely love it.
However, I have recently had a problem with acceleration and the garage have said it's my timing chain which I had replaced when I bought it so am skeptical as to this being the problem. I did a bit of research and it came up with ignition coils so I have replaced the spark plugs and the 4 ignition coils but am still having the problem.
I can't accelerate over 50mph and the fuel monitor seems to decrease quickly in 5 miles increments.
Is there something else I should try or could it actually be the timing chain.
Any advice would be appreciated.
Thank you in advance.
  • 11 months later...
Hi @Goodman Did you solve the problem? I think it could be clogged throttle body or faulty pedal sensor. You should also check timing chain again sometimes it is not fitted properly by inexperienced garage.
