IV charging issue?
Had the vrs iv now for year and a bit. Always used the 3 pin plug to charge using octopus cheap rate on night, 11.30 to 5.30..Its always charged the battery fully even from flat in those 6 hours.
This week now it's gets to about 86% and that's it, message from app says it's stopped charging, I use an alexa plug to control the socket and it works flawlessly each night, switching off at 5.31. Has anyone else experienced similar issue.
Is it charging for the full 6 hours,
but because of the cold the battery needs more the 6 x 2.3 kWh or 2.1 kWh (13.8 kWh or 12.6 kWh ) to get to 100%.   Take the meter reading for kWh used during the offpeak tariff.
You have losses charging the cold battery / cold ambient temperature.
Edited by Ootohere
Just out of curiosity, and this is going to sound a bit odd  but would putting the car under a "blanket"/cover to reduce the cold actually help it?
Edited by TheWanderer
No because the battery is above the ground and you have the Ground Temperature (Grass frost) and the Air Temperature.  A heated blanket or hot water bottle is not practical.
*Charge in a Heated Garage, maybe just not one attached to the house or under it.*
You pre-heat an EV,s battery maybe before charging when driving so that it can charge quicker when you get to a DC charger.
Like you pre-condition / pre heat before driving using the energy from your house / charger to have the battery using less energy once driving off.
Also pre-heating the car / vehicles interior.
Edited by Ootohere
Basically yet another reason NOT to get a hybrid or electric car then.
Not really for those charging Off Peak Tariff of 7 pence a kWh or less.
14 kWh needed to get 25-30 miles maybe with a hybrid on electric so £1.00 or so. or £1 for 6 hours and then 2 kWh @ 25 pence.  £1.50.
My EV last night 7 hours @ 6.7 Pence a kWh, 16 kWh, £1.12. ,  That gives me 3 miles a kWh so 48 miles or so for £1.12
If on a 6.6 kW chargers for 7 hours then maybe 45 kWh for £3.10,     45 x 3 miles a kWh is 135 miles.   That is much cheapness.
Edited by Ootohere
Odd thing is I never had these issues last year or with an hyundai ionic I owned. I'll try it on for longer than the 6 hours and see how it goes
My stupid fault... Don't know how but current limiting was switched on
