Windscreen washing pump not working
Hi everyone i am owner of 2017 superb
2 days before my windscreen washing system stopped working
When push washing arm not coming any voice from pump
İ check pump fuse (f42) its normal
But i can not find this pump relay is which one
Please help
Does the rear wash work?
If it does then it’s 100% the pump on the washer bottle itself and 2 way valve broken
Then all you need to do is remove wheel and wheel arch liner and replace
Edited by Danoid
Thanks for your repply my car doesnt has rear wash
System dont has any relay?
Not sure about relays
Does your car have xenons? If so keep activating the washer and see if the headlight washers work.
If not it’ll probably be best to take wheel arch liner off anyway and get testing with a multi meter when you try to wash your windscreen
