Coolant leak
Hi folks, i'm new to the forum and live in France. I own a 2018 Kodiaq, 2.0 litre tdi engine. Recently i've noticed that its been using more coolant (the warning light has appeared twice). I've topped it up and carried on while awaiting an appointment with a local garage. The garage looked at it this morning and said that they couldn't find any signs of a leak. What was strange this weekend was when i stopped the car, i opened the bonnet to check the level in the expansion tank, and as i did this i heard a slight noise and then suddenly the car released approx half a litre of coolant onto the floor. This happened without the engine running and i couldn't see where it came from but was in the general area of the expansion tank and water pump. The garage have suggested in the first instance to change the expansion tank, but i suspect that the problem maybe more serious. Does anybody have any experience of similar symptoms please ? Thanks, John
Hello, welcome to the forum.
Are you filling the expansion tank to the top - or just to the Max. line on the side of the tank?
Just to the max line
Assuming engine is not actually overheating, check the EV cap first, it may be releasing (or not holding) pressure, allowing coolant to boil-off early. Do you know if your engine is fitted with an auxiliary coolant pump?
To my knowledge the engine hasn't overheated although i have noticed the fan kick in occasionally when i have parked up. Excuse my ignorance but what does EV stand for please ? I'm not sure if there is an auxiliary pump..
EV = expansion vessel (tank) Fan kicking in when parking up is probably normal - either running a DPF regen - or simply calling for cooling because of vehicle stopping (no forward air flow)
TSIs have an electric, auxiliary pump to circulate coolant for short period after vehicle stop, unsure if TDIs have the same, but probably - if aux. pump is not running when required, it is likely that coolant temperature (and pressure) will initially rise on engine shutdown.
Thank you for your help so far, much appreciated
Do any fault lights show up at all before it dumps coolant?
If you can get a DTC scan done,  fault code P261A is one I have seen reported for aux. cooling pump issues.
