Skoda Octavia 2.0 TDI Cold start issue
Hello,
As the title says, I own a Skoda Octavia 2.0 TDI with automatic gear. I have the car serviced every six months, and the last service was two months ago. Recently, I faced this issue, which is attached in the video, when I cold-started the car. I don't know what the problem is or its description. I replaced my battery nearly 2 years ago, but I didn't code it to the car. What I am asking for is, what is the issue that I face on cold start? And, should I code the battery when it is replaced?
I cannot help with the cold start problem, but certainly a new AGM (stop/start) battery should be coded when fitted to a vehicle.
Yes, the Battery Monitoring System needs to relearn a new profile for your new battery.  It is highly recommended that you code in a new battery.  Get hold of an ODBEleven dongle for your smartphone.  That will allow you to code up a new battery and read all fault codes.
The crank time doesn't seem overly long, so I don't think that's a major issue.
Neither do I, your car seems to start quickly and correctly.
I don't think anyone here can answer that without more info from you, like why do you believe you have a problem.
Looking at the video, after starting there is warning light on and a message on the MFD
That message says "Manoeuvre braking currently unavailable", so I think you have a problem with one or more of your parking sensors.
Thanks for that, too small on my screen for my eyes!
Everything working correctly, I wasn't asking about the message, to be honest. The issue is the lag or the car dies for a few seconds before starting up, the lights went off and after the start, all lights in the dashboard went up, too. I don't know the correct definitions and/or description of the issue, but here is what I understand from it since this behavior only came up a few days ago.
As it's tied in with the electrics, I'd get the battery & alternator checked.
Seems like a normal cold start tbh. If you feel it is harder, check battery.
I think the OP may be referring to the slow(ish) cranking speed just before ignition. The battery sounds a bit tired to me. Could be due to not being coded in.
