Front braided Brake lines
I have a a mk1 fabia vrs with 312mm brakes and braided lines. I want to fit them onto the misses mk2 Monte Carlo 1.6 tdi 105.
I know the brakes will fit but will the braided lines fit also? Or will I have to get different ones.
If the brakes fit, the lines should fit, obviously the car needs to be on 17" rims or bigger as well.
not necessarily they are the same could be a different length and no you can fit 16s on them I had the standard VRs mk1 wheels on with the 312mm brakes.
You're right about the wheels, I was thinking of 15's Vs 16's. Knock yourself out, no-one else has fitted Mark 1 312's to a Mark 2, you'll be the first. I thought all the bits were the same so how exactly would it need different brake lines?
