Brake bleeding sequence?
Hi,
Job for the weekend... Brake fluid change.  I have always bled the brake caliper furthest from the master cylinder, then a sequence ending in the closest to the m/cyl. O
I've had a look in the good ol' trusted Haynes manual and they are saying VAG vehicles are done front to back (opposite)
Anyone know anything definitive for this question?
It's a 2011 octavia II.
Thanks!
Marc
This is what i found.
Bleeding sequence
1 -Front left brake caliper
2 -Front right brake caliper
3 -Rear left brake caliper
4 -Rear right brake caliper
As above if you let the fluid levels drop too low then you need VCDS/Diagnostics to put the ABS into "service" mode to properly bleed the air out.
Bleeding sequence
Thanks for that, same sequence as the Haynes manual.  I'll have a look at the pipes underneath, see how they're routed 👍
