SKOMAN
Hi,if you are SKOMAN and you are reading this then I'll say hello!! The reason for my post is to ask you if you still have a wiring diagram for MK2 fabia 1.2TDI that i noticed you had offered a copy to someone previously on the forum?? If so..would it be possible for me to get a copy?? I've changed quite a lot on the car and still have no turbo boost and the coil light and DPD light on the dash.id be proper grateful if you could help me!! I'm hoping you get this message,thanks😊
Dpf light
Try mentioning @skoman and he might see your message.
Hope you get the help.👍
Thanks,I'll retry ammended message
Hi,if you are @SKOMAN and you are reading this then I'll say hello!! The reason for my post is to ask you if you still have a wiring diagram for MK2 fabia 1.2TDI that i noticed you had offered a copy to someone previously on the forum?? If so..would it be possible for me to get a copy?? I've changed quite a lot on the car and still have no turbo boost and the coil light and DPD light on the dash.id be proper grateful if you could help me!! I'm hoping you get this message,thanks😊
