Front Grill Covers
Has ayone taken the foglights out on a Fabia MK3 2019 S E L it's the newer facelift with the TSI 3 cylinder engine it shows in the book to pull out the small grill next to the fog lights to gain access but i'm pulling rather hard and nothing is happening i'm afraid i'm going to break the grillls so rather than have them broken driving around i would like to get 2 new ones ready, our main dealers have shut down so would lke to buy online but not sure of the part numbers or where to buy found some on the Bay but doesn't show the car in thier list so a bit confused
Edited by Murdockman
It can be easier to look from behind the grill first.
A thin flat trim removal tool put in the right places can help to unclip all the catches that hold the grill in.
I find you want to do one clip at a time working from one end to the other.
Thanks. AG Falco
Thanks. AG Falco
My skoda is the facelift one you cannot get at the back of the fog light grill cover to push it out it's the cover with a honeycomb type pattern not the straight bar type it should come straight out but it's being a pig to remove it you use the litte ring hook tool tthrought the hole near the top if you try and pry it out you will crack the bumper and mark the paint
Sorry, mine is pre facelift but it look like a similar process.
It looks like you remove the small plastic part inside of he fog light first.
There are clips that you will want to bend in to help removal of this part.
See this:-
https://www.skoda-parts.com/spare-part/6v0853666a9b9-fog-lamp-cover-right-skoda-34888.html
Even by removing all the engine undertrays?
This helped when I removed my grill parts.
Thanks. AG Falco
