p1296 engine code
Okay so I've changed thermostat also the coolent sensor not long ago I keep getting the code p1296 when I start car when warm revs stick on lime choke is stuck on best way to describe it I've got a ram air filter on it could that be the problem thanks all
Not sure I would have said temp sensor/thermostat as well but as you changed them?? It might be worth checking wiring to temp sensor in case its damaged or perhaps the connnector. Try it without the airfilter in case its blocked.
Alasdair
Okay I've had the car for some time never reli had that code before I think it's the air filter I do have the original part so going to put on on my day of
If you have the original then as long as the filter is clean it should rule out the airfilter. It may be that the sensor or thermostat has failed. Its not unheard of for aftermarket parts not to last very long. As said check connectors and wiring etc.
Alasdair
Okay so I put original airfilter on I had the same code come back I replaced thermostat a month ago with a febi one and coolent sensor was around 4 months ago any idea ls thanks
