ODIS is not connecting to the cluster
Hi, everybody.
I have this interesting problem, on my octavia 2, I changed the cluster. The cluster from the facelift was fitted to the pre-facelift octavia. They redid the connector, replaced the immo chips in the keys. Gateway unit is 7N0... And the ABS is fine too. After the replacement, the cluster works as it should. VCDS has been coded, km set. etc... Then at home I tried to connect via ODIS and it says communication error/ cluster not found. Same error with immo. Can you please advise me how to fix this problem? I repeat that VCDS is working without any problem and does not report any error. I don't have much experience with ODIS, but I would like to solve this. And I would be grateful for any advice on what to do about it. Thank you all very much
  • Administrators
Might be a DDL error with software. This genuine software or a cracked copy? If it’s the latter, I’d suggest speaking with whom ever you got it from.
It's the second option, anyway I don't understand that before the cluster replacement it was clean... Someone changed the radio before me and that left an error too. There was an Amundsen and it was replaced with an Amudsen+
