Headlight/bonnet panel gap
Hi, 2019 sportline here. Noticed the other day that one of the headlights has a pretty big panel gap against the bonnet on one side (close to where the grille is)
This particular side you and slip your finger tips through the gap and feel the rubber seal of the bonnet. The other side you can't.
Is anyone elses the same?
I did notice this particular side the rear screw which secures the headlight to a metal brace (going above the headlight) seems to have alot more 'thread' available to tighten, however the gap at this part of the headlight seems ok.
There doesn't seem to be any play in the headlight (suggesting all mounting tabs are intact and not broken) I did however notice that the side which has the bigger gap I can fit my fingers between the top of the headlight casing and this metal brace, whereas on the other side I can't.
Any ideas at all?
Edited by s88urd
