Enyaq Rattles (VRS) and Canton
So having my Enyaq a few weeks now (had 6k miles on it from new) I've got a door rattle/squeek in the drivers side and seemingly have one that is also in the centre of the dash behind the screen - that when it gets going is really bad! I've videoed it as well.
The door rattle is going back to Skoda but doubt they will do the dash whilst I wait - that could be a big job!
anyone else suffered stuff like this at all? what did you do or have done to resolve it?
Also the Canton system is atrocious! I've come from an Audi black edition and you can't even turn up this system without the speakers distorting - I've even got the MAXX pack with upgraded system - how on earth can it be improved?
Rich
  • Administrators
Heard of it before, so it's not new.
As for the Canton, play about with the settings and be sure to turn off surround sound. Some of the new Fabia's and Octavia's without Canton sound pretty good.
Cheers @Dean - I'll have a look at the settings again - interesting about Canton - I saw a post somewhere about how bad the sub it and how there's little to no space around it.
I'll turn off surround sound - as think that's on - how come?
  • Administrators
It's the default setting. There was a discussion about it in the Octavia section, and there is a guide on peoples impressions of setting up the best sound. It might be good to try a few different settings and see if you can get it improved. As for the sub, they're pretty week...
I set the sound to the front speakers on the Octavia with an EQ of;
6+ Bass
0 middle
+2 Treble
+7 Subwoofer
Canton Surround off.
Here's the guide in the Ocbtavia/Superb sections
Of course, this is all subjective. So play around with the settings, and you might be able to pin down the vibration somewhere.
Also, aclot depends on your source of music. I always prefer .Flac files and bring hardwired for the best sound in the car.
Edited by Dean
It's going in to the dealer for the vibrations on the 22nd. I worry they will fob me off as a dash centre vibration will be a big job to do with no real outcome of knowing what it is.
The stereo is better with the settings but still not great. Slightly frustrating tbh, on a car costing nearly £60k and an upgraded part as part of the max pack is very poor.
  • 5 months later...
@Funkyfin2001 did you get your rattles sorted?
No! They have seemingly gone away i think! Certainly not noticed them as much!
  • 7 months later...
Have had similar annoying dash rattles. Much worse on rougher rural roads and at higher speeds, so it's hard to reproduce for the dealer. Very hard to locate, but appears to be under the upper portion of the dash top surface.
  • 5 months later...
I've had the car in today for it - I am about to go and pick it up - its very loud on bad roads and happens pretty much every drive, its really bad. I videoed it several times for the dealer, I have just been told they have done nothing about it and to bring it back when its worse! I'm about to loose my rag! I also have the same one in the drivers door as well.
Recently Browsing 1
