3rd brake light seal
Hi all, looks as if someone has attempted to pry the third brake light out of my estate at some point, its done in the little rubbery seal around the lens and the plastic doesn't sit flush to the spoiler anymore. Is there a way to fix that or is it a case of replacing the entire light unit?
Thanks!
I replaced mine with an aftermarket one that didn't quite fit so used black silicone sealant. Worked perfectly.
Alasdairr
Alasdairr
Ah nice one! Might be the way to go with silicone! I noticed one of the bulbs has failed so ill gave to attempt to pop it out and replace it! Or I may just get a new unit completely ar some point with a fresh seal
