Karoq 1.5 Manual Rubbing/whining noise
Hi, I have a 2021 1.5 manual karoq, which has 8500 miles on it. On idle it makes a rubbing noise that disappears when the clutch pedal is down. It doesn't sound like a DMF noise, they normally clatter and bang. It could be the thrust bearing. On such a low mileage vehicle i wouldn't of expected it to happen to any part yet. Its got 12 months skoda warranty. However not every clutch part is covered. If anyone has heard of this before I'd be interested to know. I could just drop the box out and replace everything. But I'd rather not throw money at it. If its a common output shaft fault or something similar I'll just take it to them. I don't really want to leave it with them if I'm likely to get stung. Cheers
Had a similar noise on my partners previous car that disappeared when the clutch pedal was depressed. It too was low mileage, but the number of gear changes per mile was high due to just doing short journeys around town and no long runs. Had the clutch replaced and it was fine.
Interesting. The previous owner had it for 3 years and only put 5500 miles on it.
Thank you.
Problem was resolved. Internal gearbox fault. Its the expansion screw under the end cap which needs replacing. 007 671 b.
