Light on then goes off. HEATED SCREEN
Hello All
My screen stopped heating effectively a while back then one day the light went off after about 2 seconds…… any ideas please?
Thanks so much
Dan
Its broken.
Oh goody…. A funny guy! 😂
It does sound like it is, though!
Ford ones delaminate at the edges with time and stone chips don't help the wires apparently.
First check the fuse.
Then, remove switch & check voltage to switch. Turn on & check voltage out. If you don't have voltage out, replace switch.
If all seems ok, then check voltage to the heated screen.
Obviously with the ignition on.
Edited by Carlodiesel
