Amundsen music sometimes resets to 'A'
I've got a 2016 '66' reg VRS with the Amundsen headunit. One SD card is for the built in sat nav data and I've put another SD card in the other slot with a load of music on it. The battery on my car seems fine - it never struggles to start even in cold weather after not being driven for a week or more. I have got a '70mai M300' dashcam with 'UP02' hardwire kit fitted. I might try disconnecting the dashcam but sod's law says that'll be the moment something happens when I really need it.
Sometimes when starting the car it resumes the last song that was playing but other times it resets to AC/DC (which is probably the first artist in the list). Now as much as I like AC/DC, I don't want to listen to it all the time and the intro to 'Hells Bells' is starting to lose its awesomeness. You could say I'm on a bit of a highway to hell ;)
Has anyone else experienced similar and managed to fix it? Alternatively can anyone recommend any bands before AC/DC in the alphabet?
Abba
My 68 reg Octavia did this, as does my 23 Karoq, both using USB drives. Seems to be a continuing problem with Skoda. Recent traffic in Karoq site shows Skoda know of it, but may not know how to fix it (or don’t care). Mine reverts to America and A Horse with no name!!
Just check the firmware on your MIB2.5 system. This issue with incorrectly picking up the wrong location on the SD card - was a bug.
For MIB2 Amunsden and Bolaro systems, you need to be on version 0480 (for SOP 4.x). Anything less than this - and you need a firmware update.
If you are running 02xx firmware, its version 0253, if its 03xx firmware, then it should be 0363, if its 04xx, then it should be 0480.
Press MENU (and hold for about 3 secs), go to firmware and firmware version.
