Potential EV virgin
On 09/07/2025 at 12:00, Aspman said:
I think we've already got a 100A main fuse, it's max domestic supply without going 3 phase
These fuses will supposedly run at well over their nominal max amperage but one does not want to push it and have to call out the Grid to replace as most electrician will not touch anything Grid side one electrician told me.
  • Replies 52
  • Views 6.3k
  • Pulled the trigger on the ID3, the numbers were too good to say no to right now. Bumped the mileage to 15k for another £15 a month as long as it's silver. Black is cheaper than silver on 12k. Have as
  • From a Skoda point of view, I think only one of the Enyaqs creeps below £40K? if you don't mind a smaller boot, Elroqs give you more choice including a bigger battery option. I believe rear seat space
  • Just ordered, my son actually, a new electric mini, the E rathervthan the SE so the small 36 kwh battery. Lighter than the SE with the 49 kwh battery and elreports say better dynamically for it. O to
@Aspman What is the Countryman that is getting moved on?
I was going to Aberdeen to look at a PHEV one and noticed what you put in another thread.
It's a 2019 JCW. So nowt like a hybrid I'm afraid. 30mpg if you're lucky
