Dash warning lights but no faults
Mk1 Fabia 1.4ltr 16v petrol, 2002. Warning lights and bleep showing intermittently, but dealer's reader shows no faults. I get steering, EPS and ABS lights, plus the bleep, coming on while driving. Sometimes restarting will clear some or all. I cannot detect a problem in the steering.
Also possibly related is that the RH green trafficator dash light isn’t illuminating.
My suspicion is of a failure in the dash module itself, but I would appreciate opinions and suggestions. I've owned this car from new, it's done over 130,000 miles, and been dealer serviced every year.
Sons 1.2 fabia did this and it was a crack in the strip fuse in front of battery. Would start and run for a while then beep and warning lights. His had ABS and brake warning light but not the EPS if I remember. Car seemed fine to drive. Restart and it was ok sometimes then beep again and lights with no stored fault codes. Crack was so fine you could hardley see it.
Alasdair
Check strip fuses, and also the earths also. Mine had an electrical strop when the earth connecting to the inner wing wasn't making good contact.
