Parking sensor problem
Hi
I have suddenly got an error with my parking sensors on my octavia 2016
When put into gear an alarm sounds and the picture on display is attached image.
Since the exclamation mark is shown on the rear of car i guess problem is with the rear sensors.
I have checked all rear parking sensors and they all have the same resistance between pin 1 and 2 and its unlikely that all are broken at the same time.
The cables all have power between pin 1 and 2 and all cables have no visible damage.
I do not have access to a vcds to check errors at this point.
Is there anything more i can check without visiting a repair shop with a diagnostic tool?
//B.
It happened to me, a sensor had been stained with resin
