engine noise increased on speed rotational
hi all new to the club!!!
noise heard inside cab
Can anyone help while driving at around 30mph rotational engine noise appears then gets louder at 70mph then when reducing speed from 70 to 50 louder rotational noise sounds a a tyre but is not all new tyres front left fronway front right debica
rear left fronway rear right old conti eco6
also does tramline
tracking done saw him only adjust driver side
happened after replacing a battered damaged front driver side shock absorber
checked bearings nothing
could this be a a slight leak from the rocker cover???
or the undertray slight broken???
Edited by tantheman
uploading video
Which model, engine, gearbox?
Welcome.
How did the shocker get battered?
Was there a kerbing / pothole incident?
Why did you not pay to have both shocks replaced?
If you have un-matching tyres on the same axle then some noise might be expected.
4 wheel alignment done by a competent person might be a good idea.
& things in pairs that match.
What is the Rocker cover about.
thanks pal
rocker. over seals leaking puddle of oil not diesel fuel
the shock driver side was a year old brand new genuine and again brand new genuine it was knocking like loudly must have been a faulty batch all documented and fitted in front of me by competent experiences mechanic with right tools
replaced all hardware pinch bolts top shock lock nut and mounts but reused on new shock absorber driver side just the mounts reused as deemed perfect working parts rest new nuts shock and reused sachs spring as in good solid condition
if i could post pictures id put them on here
alignment done with hunter tracked straight best fuel economy shell diesel
I didnt hit any pot holes thank fully always on the look out and going around them or really slow
I drive very consciously believe it or not and never hit the pedal
it boils down to affordability its a lovely car mostly done motorway miles drives a dream but funds for all these repairs
Ive bought the genuine bits
I got another brand new genuine shock absorber for the left side waiting to go on
im guessing the rears need doing mot guy marked them yellow cross
unfortunately I cannot post the video I have of the noise its so clear
i agree on tyres but again cost affordability
Ive always done an oil service using genuine quantum oil ll3 fro TPS and oil filter
funny thing is with the rocker cover leak it isnt consuming any oil
just puddle around the seals over dripping down to tray
not the ground
thanks for your reply
the terrible
skoda octavia 3 year 2017/18 facelift 1.6 technogy manual 5 speed gearbox midnight blue
5E3 DDYA gearbox code RTD
any help with this blasted noise please any suggestions im at witts end now been like this a while now do anyone knows what it can be???
Edited by tantheman
noise has git louder high pitched both in neutral braking and increased speed
