Keyless access faulty. Keeps beeping whilst driving
Hi all.
New fault with the car. Skoda superb 2016 lnk 2.0 tdi.
A message appears on the dash. Keyless access system faulty. Keeps beeping whilst driving.
Ive tried turning keyless entry off via vcds and hasn't made a difference.
Vcds scan shows short to ground on driver side door.
Has anyone had same problem that can advise?
So far the solution looks like a new door handle but would like a second opinion before replacing.
Only way I can drive in peace is by keeping vcds connected to the car and clearing rhe code whilst driving
Might be worthwhile checking the loom in the hinge and door first.
  • 6 months later...
On 11/07/2025 at 17:31, gidi19 said:
Hi all.
Hello, I have the same problem on my superb.
Did you manage to fix it and what was the cause?
To be honest, I don't know how but it sorted it self out.
At the time I thought it was because it was getting too hot due to the hot weather we had at the time.
I managed to solve the problem, I replaced one of the door handles in my case the right passenger side was broken and it caused these problems.
