help! felicia headlight won
Hi my skoda felicia headlight won
If you use a different colour to post in it would be easier for us using the fusion skin to read, but I can just make it out.
The solution is allready on here but i'll post it again anyhow. The system cant be repaired, the whole lot has to be replaced, forget that. Take out the adjuster unit and wind the rod out (phillips screw in the end) and then insert the adjuster back in and adjust manually.
If you use a different colour to post in it would be easier for us using the fusion skin to read' date=' but I can just make it out.
The solution is allready on here but i'll post it again anyhow. The system cant be repaired, the whole lot has to be replaced, forget that. Take out the adjuster unit and wind the rod out (phillips screw in the end) and then insert the adjuster back in and adjust manually.[/quote']
i wonder who taught you that one :P
the master himself :thumbup:
Had to do it at work the other day on an MOT for the tester. Impressed them with my Skoda knowledge ;)
I had the same problem and I decided to adjust them manualy and forget about remote adjust. I found the problem as a cracked adjuster on both sides. You can see the crack on the upper side of adjuster. That makes the fluid to leak...
