2012 1.6tdi fabia estate (scout to be specific with projector headlights)
Hi all got a strange issue with a Fabia scout estate 1.6tdi 2012 when you turn the dip beam (and only when they are turned on ie even the likes of the wipers wont put the light on so defo not charging related but something else) on both the battery light and window washer level warning light come on, Is this a common issue anyone has seen before (and of course what was the issue) other than that any ideas as to whats causing this
Had weird dash lights on my old octavia. Some dim others bright. Fog light symbol on when lights were on all the time (full and dip) plus dim battery light and dim DPF and a few others. I worked out it was an electrical fault as it didnt have a DPF. Removed cluster and cleaned contacts and then reconnected and it was fine. The connector at rear of cluster was either loose or had some corosion. Remember to disconnect battery if you are removing cluster to stop imobilser coming on.
Ok cheers much appreciated will keep in mind and have a look at this being one of the possible scenarios :) anyone else anything ideally exactly the same issue as mine or similar?
