Sudden problem with air vents. Making a really loud noise.
I wondered if this might be a common problem that someone else might have come across. With the air blower turned on it sounds like the noise made by holding a stick against a rotating spoked wheel. Very loud when on the highest setting. Sounds like something hitting the fan part wherever that may be. Is this going to mean taking the dash off to try and find what is causing the obstruction or interference in the ducting somewhere? Thanks for any help.
I think it's a case of removing glove box - fan motor etc is behind
Ah, ok. I guess that might not be too difficult. Thank you
You were right. It was an Asda fuel receipt that got sucked up from the glove box into the hamster cage fan attached to the motor. Thanks!
5 hours ago, NCC-74656 said:
Asda fuel receipt
Hello, Scooter.😉
Thanks. AG Falco
9 minutes ago, AGFalco said:
Hello, Scooter.😉
Thanks. AG Falco
Hello there. Though I'm pretty sure we don't know each other, if that was implied by the Asda reference or wink, as we're at different ends of the country.
Correct.
I am also on the UP forum as I have both an UP and a Citigo.
Thanks. AG Falco
