Cost of wiring loom from cabin to drivers door
My airbag warning light will not go off. Found broken wire in loom that goes into drivers door. What is the part number please .
Easy to repair in situ. If you are not happy to do it yourself or don't have a friend who can do it, then about half an hours work at an auto electricians.
Probably less time than changing the loom.
If the wire is broken I normally just solder the wire together but if its at a point where it gets flexed if near a door hinge I tend to replace a section so the join isn't getting stressed. I generally solder a new section in and use heat shrink to cover the joins pus some insulation tape for extra protection. A lot cheaper and easier than replacing loom.
Alasdair
Thanks guys.
