gauges....?
To those that have fitted them allready, where do you run the loom into the engine bay? (gauges will be under the stereo in the 'cubby hole' slot. Also where do you take the oil pressure from as the existing location has a switch there i guess for the oil warning light (i will be using the 'spare' blanked apperture for oil temp. Thanks for any info........:thumbup:
P.S. got stealth 2 gauges, the ones that blackout when off.
J.
Dont know about the loom but my only man just wired them up from the head unit feeds on his scooby.
As for the oil you need this mate
http://www.42draftdesigns.com/oil18t.htm
Thanks for the clicky, where do i get said item from..? Ta much, J.
err in all honesty mate ive no idea where you would get one. i think that some guages come with teh said item
My oil temp gauge came with the sender to go in a sump plug. I haven't checked yet it it'll fit in the alternative location.
Must have a look this weekend.
The oil temp goes in the 'spare' blank on the oil filter housing i think, just need to sort oil pressure. Where do you run the wires into the engine bay (where in the bulkhead that is)?
Ta for the info so far.
There's a grommet behind the glovebox. The glovebox comes off with five torx screws.
This is a pic from the engine side - you have to remove the plastic trim from under the wiper and it's next to the pollen filter.
There's more pictures here from when I fitted my amp, might help you!
Excellent clicky, cheers dude. i'm gonna have a go tomorrow.
where did you get your blackout gauges from mate? and how much were they?
www.gaugeplace.com
Speek to NICK GILCHRIST there, he's a top bloke and gives excellent service.
(i have the same gauges as Rob btw).
