ESC error after battery went flat
Battery went flat yesterday during the window regulator changed. Charged, vehicle starts fine, managed to clear all the Christmas tree of other faults which also got thrown up, but left with this one which won't clear.
Address 44: Steering Assist       Labels: 1K0-909-14x-GEN3.clb
Control Module Part Number: 1K0 909 144 P
  Component and/or Version: EPS_ZFLS Kl. 196    3305
           Software Coding:
            Work Shop Code: WSC 33361 790 00050
                      VCID: 372B2BC1234E7A627F9-8062
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    Battery Volts: 10.5 V
                        PD
                    Temperature: 16.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 0
                        SteerAng n.Init
Any ideas?
Either take it for a drive or turn steering wheel lock to lock and should clear
Thanks David. I was thinking I should have probably tried this!
Problem solved. Thanks @David6253
