Remote central locking issues
morning all, having issues with my key fob/ remote central locking. Started a few weeks ago, basically the fobs don't work (both), red light comes on but nothing. The car will unlock manually, and the car starts. But a few opens/closes the alarm doesn't seem to beep when manually unlocking (but it does unlock). After a 30 min drive, it started working again both fobs. Flash forward 2 weeks and two 7 hour drives later, and the same is happening again. I have replaced the fob batteries, and tired numerous resyncs but nothing. The same strange manual unlock with no beep is also happening (until I start the engine and run it) then the alarm beeps when locking/ unlocking.
It seems like maybe this is low voltage issues ( main battery), would explain the long drives and it working. But the car starts well, no slow crank.
checked the main battery, charged it as well - no change- but this morning i opened the car (manually) to put stuff into the boot, and it started working again - but stopped working when i got to work.... clearly intermittent, but not sure
Any thoughts
It's a 2012 2l tdi
Check the dash display for a door open icon every time you open the driver's door. If it doesn't display then check for a broken wire(s) in the cable trunk from the door frame to the driver's door.
A broken wire (intermittent) here doesn't answer all your points but does answer the beeps and alarm issues.
thanks for th help - think i have managed to find the issue - turns out it was something to do with the actual ignition switch (or ignition lock) - when i took the key out, it would come out and there was no click - when this happened i would have the alarm issue - but a quick jiggle removing the key, i would get the click and the alarm would work.... very very odd
You are quite right, its the ignition switch at fault, Apparently its a known issue on VW Caddy vans using same unit. Its down to wear, the click you hear when pulling the key informs the computer that the key has been removed and the alarm system can set. If there's no click it gets interesting because the computer has conflicting inputs. New lock coded to key sorted it at independent VAG workshop but not cheap.
