Jolts and Hiccups
Hi all
I have had my 2019 Skoda Octavia 1.9 SE L 4x4 DSG for about 18 months now, no issues, 49k on the clock and well looked after. Recently had a major service, no faults.
I’ve been noticing that on acceleration the car will jolt and hiccup and few times before returning to normal. I can drive it for a few days without any issues, then all of a sudden it’ll do it a number of times through a journey then return back to normal. Sometimes it can be when pulling away at low speed and it will give a major jerk and carry on, sometimes it can be at high speed. At first I thought the gearbox but I’ve been experimenting when it occurs making sure the gears aren’t changing or I’m going 70 in 7th, it’s also happened mildly when at idle once. It’ll stop when I take the foot of the accelerator and then continue when putting my foot back on before going back to normal. I’m 99% sure now it’s something in the fuel delivery. Like I said it’s just had a major service. I have a decent fault finder / reader, it’s not throwing up any codes. I have just changed the fuel filter, the air filter and run some engine cleaner and fuel injection cleaner. My thoughts are maybe something to do with the fuel injectors or fuel pump, but just wondered if anyone else had any better ideas or similar experience?
Many thanks
I had a Nissan Note years ago that did something similar, turned out it was missing firing but not throwing up a check engine, root cause was some damaged wiring.
Is your scanner capable of detecting VW codes? If not you should probably get a scan done for VW specific codes I had a middle of the road Autel unit but as soon as I got an obdeleven unit I found over 20 VW specific hidden codes
After searching through previous posts, there is talk about replacing the crank shaft and cam shaft sensors. So will look at that
